nialle Posted July 9, 2013 Share Posted July 9, 2013 Is it safe to run a ct9 at a bar? What would my base fuel pressure need to be im running a sard rrfpr? Any help would be great cheers Quote Link to post Share on other sites
Weyro Posted July 9, 2013 Share Posted July 9, 2013 if you have all the other supporting mods. 44psi Quote Link to post Share on other sites
nialle Posted July 9, 2013 Author Share Posted July 9, 2013 Well wen i got the car it was running .9 but was on standard mani n actuator so swapped those for aftermarket as was warned by td that it wasnt a good idea lol but wen i fitted my actuator i set it to .8 but now am bored n want a bar lol it has a fcd on aswell what is 44 psi in bar? When it was running .9 it had base of 2bar but obv increased on acceleration due to rising rate :/ confuses the living shit outta me all this lol Quote Link to post Share on other sites
Weyro Posted July 9, 2013 Share Posted July 9, 2013 hmm thats weird, stock is 2.4bar44psi is about 3barwhat kind of FCD do you have? Quote Link to post Share on other sites
nialle Posted July 9, 2013 Author Share Posted July 9, 2013 Its a hks 1 and yeah i was told that :/ but went on rollers at td n was fueling fine apparently..... Maybe because it didnt have the hks actuator on so wasnt holding the boost thts why i turned the boost down a touch when i fit it lol Quote Link to post Share on other sites
AdamB Posted July 9, 2013 Share Posted July 9, 2013 Set it at 3 bar and have it setup with a wideband, doesn't take much to blow an engine mate. Quote Link to post Share on other sites
nialle Posted July 9, 2013 Author Share Posted July 9, 2013 I know yeah thats what im worried of haha Quote Link to post Share on other sites
AdamB Posted July 9, 2013 Share Posted July 9, 2013 You'll be fine if you set it at 3 bar and just drive off boost till its checked Quote Link to post Share on other sites
Weyro Posted July 9, 2013 Share Posted July 9, 2013 setting 8 on the hks should raise boost cut to around 1.15-1.2bar, so allow you to run 1bar Quote Link to post Share on other sites
loz180691 Posted July 11, 2013 Share Posted July 11, 2013 I've got my ct9 at 1bar on emanage quality set up running 210 bhp the spool up is so quick and pulls great Quote Link to post Share on other sites
glanza sheehy Posted July 11, 2013 Share Posted July 11, 2013 I've got my ct9 at 1bar on emanage quality set up running 210 bhp the spool up is so quick and pulls great what emanage do u mind me asking? thinking of doing the same. Quote Link to post Share on other sites
loz180691 Posted July 16, 2013 Share Posted July 16, 2013 Blue tuning developments sorted it out for me defo recommend Quote Link to post Share on other sites
EP-Azz Posted July 17, 2013 Share Posted July 17, 2013 How did you get 210? I only reached 197 and that was at a bar almost and I'm on a hybrid Quote Link to post Share on other sites
