Is that the noise when off acceleration I can hear? Sounds like a metal ( spinning )kinda noise ? :/
Edited by Danza V
Off acceleration , but i think yeah it happens when driving car for example what ever rev range but when revs drop between 2-3 then makes the noise aswell?
What could it be , does sound like its under rocker cover, but no loose metal or anything in there
Edited by Hawwy
Even when its warm it does it.Its a tmd engine, bottom end everything is in okay just the top sounds like right under cam cover may not be though
Edited by Hawwy
Plugs tight had new ones, well it was like that when i bought it, somebody has said something to do with cams tensioning or along them lines
I'd check the turbo, like just have. Fiddle of the shaft, or even get a stethoscope on it. You checked down the belt side. Maybe it's a pulley or something ?
