Chris Green Posted July 17, 2013 Share Posted July 17, 2013 Hi guys, Just got a new genuine Toyota oil pump, but they are slightly different. The one which came off the engine has a recess for the seal to go round the actual centrifugal pump whereas the new one doesn't. What's the story is it the wrong pump, which way does the new one seal? Cheers. Quote Link to post Share on other sites
Idrees Posted July 17, 2013 Share Posted July 17, 2013 Chris, does the old pump have the seal recess on the pump? Check the block, does the oil seal fit on the block or on the pump? Quote Link to post Share on other sites
Chris Green Posted July 17, 2013 Author Share Posted July 17, 2013 Ah, just dropped you a PM. I will have a check now. Quote Link to post Share on other sites
Chris Green Posted July 17, 2013 Author Share Posted July 17, 2013 Just checked, there is no recess on the block, just the old pump. Quote Link to post Share on other sites
Idrees Posted July 17, 2013 Share Posted July 17, 2013 You need a different pump mate, PM replied. Quote Link to post Share on other sites
