Hi guys
I'm suffering boost creep to about 0. 9 Bar ish , I'm goma port the turbo and mani bit want to know should I remove the fcd before or after as I do have a lead foot.
Any advice please peeps
I'd say remove the fcd altogether man unless there's proper fuel management fitted. Bit dodgy hitting .9bar without fpr/emb etc. Make sure you port the wastegate hole out it helps prevent boost creep
Removed fcd and set hks to 0.5. Now creeps to 0.7 ish so safe now. Gonna port wastegate when I have the to remove turbo etc
You can run it so it creeps to 0.85 bar safely without fcd as max I'm running is 0.85 before it will hit fuel cut which mine don't hit at all.
That's how I'm running and it's sweet as a nut :)
Edited by Ep'd
