Ep'd Posted July 27, 2013 Posted July 27, 2013 If I fit a mbc manual boost controller will I lose the option of the hi low turbo button?Also to fit the mbc will I need to do the bypass which loses the hi low turbo function? Quote
Ryan_EP82 GT Posted July 28, 2013 Posted July 28, 2013 Yea mate I think you lose your button because the mbc is plugged into the actuator lines. There should be a fitting kit to tell you which lines goes to the hose and which to the actuator. Or someone on here will tell you. Quote
