jayc-glanza17 Posted July 29, 2013 Posted July 29, 2013 im going to hook an adaptor up to stock pressure sensor position and run my pressure gauge off that adaptor, is with oil cooler cant run a sandwich plate as its a mocal thermostatic one with a sensor connected to my omex. http://www.speedflowshop.co.uk/18-bspt-oil-pressure-gauge-adaptor-5000-tp8-1705-p.asp Quote
A L 3 X Posted July 29, 2013 Posted July 29, 2013 Don't get that, it may destroy your engine!!!!As you may have read I put a topic up about an oil leak I recently had, with the same setup as you mention above, anyway long story short it was coming from that, when I went to loosen it it sheared off, spent an hour getting the piece out of the block and have now replaced with a remote mounted t piece kit to stop the weight of the sensor snapping it.I only assume the leak was where it was cracked and if i hadn't sorted it sooner it would have snapped and pissed oil everywhere! Quote
