FrancyGlanza Posted July 30, 2013 Posted July 30, 2013 (edited) basicly Heads wrecked with the car the last couple of weeks!! valve seals and rings were done 8000k ago with a athena 1.4 headgasket its burning alot of oil on boost, but yet it doesn take any when off it its smokey on boost and smokey as you come off boost checked turbo and everything seems fine, no oil in exhaust side etc.. its blue/black smoke put a new PCV valve on it to done a compression test to and came up 10 bar on all cylinders cheers in advance Edited September 6, 2013 by FrancyGlanza Quote
Flaminsam Posted July 31, 2013 Posted July 31, 2013 Yea 6.5 is low on compression. You should be looking around 10bar at least with no greater variation of 1 bar across all four. Quote
AdamB Posted July 31, 2013 Posted July 31, 2013 That's very low compression. Did you try a wet test? Quote
FrancyGlanza Posted July 31, 2013 Author Posted July 31, 2013 yeah ino compression is very lowdidnt do a wet test but i may to see if its rings but i dont tink it iscould timing affect compression ? Could Be valves ? stem seals ? Quote
AdamB Posted July 31, 2013 Posted July 31, 2013 The engine timing will affect the compression yeah, but that's clearly not your problem if its burning oil. Sounds like a ring sealing problem to me, could well be valves but it would be very unlucky to happen on all 4 cylinders. Quote
FrancyGlanza Posted July 31, 2013 Author Posted July 31, 2013 Was warm alri but not sure with the wot tho Quote
Danb Posted July 31, 2013 Posted July 31, 2013 If throttle was not wide open then pressure results will be low (like yours) Quote
FrancyGlanza Posted August 21, 2013 Author Posted August 21, 2013 Test done with WOT and reached just over 7 bar would the 1.4 headgasket not make it as low ? for a car that has low compression it pulls like a train Quote
FrancyGlanza Posted August 22, 2013 Author Posted August 22, 2013 Got a compression txt with another tester and came 10 bar cross all four :/ Quote
FrancyGlanza Posted September 5, 2013 Author Posted September 5, 2013 Any anything else ?Still doing thisCompression was done again twice with two different testers both came up 150psi across all cylinders bang onBoth side of turbo are dryDoesnt smoke on idleSmokes abit on boost and as you come off it and put throttle back down puffs a smoke comes out I think myself it is valve seals but want to be sure ? but they were only done ? Quote
