1990timeismoney Posted July 31, 2013 Posted July 31, 2013 Hi trying to get a ep82 circuit diagram is there one available or any idea we're to get one.Thanks Quote
glanzagee Posted July 31, 2013 Posted July 31, 2013 Which pat of the diagrame as it comes in sections Part Quote
1990timeismoney Posted July 31, 2013 Author Posted July 31, 2013 The part that shows the resisters I've got one that needs to be replaced but wanna make sure it's rite Quote
glanzagee Posted July 31, 2013 Posted July 31, 2013 no toyota book is going to show you circuit diagram of the ecu sorry if it was the body or engine loom id be glad to scan a few pages out the book Quote
1990timeismoney Posted July 31, 2013 Author Posted July 31, 2013 http://www.ukstarletowners.com/topic/68435-ecu-resister-blown-help-needed/?fromsearch=1 Quote
1990timeismoney Posted July 31, 2013 Author Posted July 31, 2013 Thanks mate that would be much appreciated I've attached the link we're u can see the resister worn.any advice or info on the part would be great Quote
AdamB Posted July 31, 2013 Posted July 31, 2013 (edited) What number or marking is on the board mate? I got some diagrams here but I doubt it will be noitceable. Edit.From your pic it looks like number 14? Can't see too clearly though.From the ECU circuit diagram, number 14 has something to do with either the A/C amplifier, believe something to do with air con, or VSV duty, possibly something to do with the original Hi/Lo solenoid. I could be completely wrong though lol. Edited July 31, 2013 by AdamB Quote
1990timeismoney Posted July 31, 2013 Author Posted July 31, 2013 What number or marking is on the board mate? I got some diagrams here but I doubt it will be noitceable. Edit.From your pic it looks like number 14? Can't see too clearly though.From the ECU circuit diagram, number 14 has something to do with either the A/C amplifier, believe something to do with air con, or VSV duty, possibly something to do with the original Hi/Lo solenoid. I could be completely wrong though lol.That sounds spot on mate reason it went was because re wired the loom for the mk1 ecu into mk3 and put wrong wire in lol will try and get bord number its a mk1 ecu.Been a great help it seems to work ok but just need to no what the resister is to replace it to be safe. Quote
AdamB Posted July 31, 2013 Posted July 31, 2013 Unfortunately the wiring diagram doesn't list any resistor values Not the one I have anyway. If you have a standard ecu I would be inclined to open it up and check the resistor values that are either side of your blown one, if they match up with the HRF, I think you will be pretty safe in copying the resistance value from the stock ecu. Quote
1990timeismoney Posted July 31, 2013 Author Posted July 31, 2013 Ok mate ill give that ago ill try and buy another ecu and use a original resister. Thanks again.Luke Quote
