Collins611 Posted July 31, 2013 Posted July 31, 2013 What's am I settin fuel cut to number - ? And what psi on fuel pressure reg - ? Many thanks Quote
mikey4410 Posted July 31, 2013 Posted July 31, 2013 i am pretty sure fcd should be on 7 or 8. on a td04 i would start very high on the fueling as thats safer.see what you get on ure a/f gauge with the fueling at 45-50 psi. im sure somebody on here will let you know a definate fuel pressure number but it depends if ure fuel pumps upto it aswell etc. Quote
AdamB Posted July 31, 2013 Posted July 31, 2013 Get it checked by a tuner. Setting the fuel is easy, monitoring knock isn't. Unless you got access you some det cans I would play safe and set it at 3.2 bar and take a drive off boost to the tuners. Quote
Collins611 Posted July 31, 2013 Author Posted July 31, 2013 Sweet cheers guys got one ready to go on tomoz just want it safe Get it dynoed on a wideband ? Quote
AdamB Posted August 1, 2013 Posted August 1, 2013 Doesn't have to be on a dyno. Just someone who has det cans and knows what their doing in terms of setting it up safely Quote
Collins611 Posted August 1, 2013 Author Posted August 1, 2013 Det cans ? I got a mate who has a wide band dyno as I set it up obviously put wideband on the exhaust tip then start up to see if its running lean or rich ??? First td04 I've done so wanna get it ringht sorry for the newbie questions Quote
mikey4410 Posted August 1, 2013 Posted August 1, 2013 Adams right,do what he says .if your unsure then always go to a reputable tuner.!! Quote
AdamB Posted August 1, 2013 Posted August 1, 2013 Det cans allow the tuner/person to monitor knock levels by listening to the engine ping. There's too many things to list as to what causes an engine to knock, but setting up the fueling is only one part of the equation.Knock is the biggest killer of engines, and no power is gained through setting the AFR. It is possbile to set up an engine just through fueling but in my experience it's only half the job. Any questions, fire away that's what we're all here for Quote
