MikeyMoore Posted August 7, 2013 Author Posted August 7, 2013 hmmm still quite abit of oil spitting out the dump valve :/ Quote
rinseep82 Posted August 7, 2013 Posted August 7, 2013 May just be oil left in from you overfilling give it a few days or change your dump valve Quote
RobSR Posted August 7, 2013 Posted August 7, 2013 (edited) Sounds like exhaust side turbo seals mate take of your inter cooler piping from the turbo and look in there if there's oil it's the seals If its spitting oil out the dump valve it wont be the turbo seals on the exhaust side lol - if it was, the oil would be going down the exhaust. Itll be compressor side oil seals if its still spiting oil out the blow off valve and if its sitting in the IC piping. If its smoking, it could be both compressor and turbine side. If so, take off your downpipe and check for oil round the back of the turbo. Edited August 7, 2013 by RobSR Quote
rinseep82 Posted August 7, 2013 Posted August 7, 2013 Oil can spill into the compressor side when the exhaust seals have gone iev just had this in the past few days if there's thick white smoke it's normally exhaust side but I didn't kno at the time it had been Overfilled Quote
RobSR Posted August 7, 2013 Posted August 7, 2013 Oil can spill into the compressor side when the exhaust seals have gone iev just had this in the past few days if there's thick white smoke it's normally exhaust side but I didn't kno at the time it had been Overfilled Id be very very surprised if your oil seals had gone on the turbine side, and then the oil somehow made its way back up the shaft, and past the compressor side oil seal. If it was only the turbine side gone, it would come out of the easiest point, i.e be going out the back out the turbo down the exhaust. Quote
MikeyMoore Posted August 8, 2013 Author Posted August 8, 2013 well there isnt really much smoke, just the dump valve makes a chatter noise sounding like its blocked and spits oil out, ill be taking the top mount off today and will have a look Quote
StuDoc 72 Posted August 8, 2013 Posted August 8, 2013 Theres probably a load of oil in the tmic if it was run while over filled. Quote
MikeyMoore Posted August 8, 2013 Author Posted August 8, 2013 cleaned as much as i could, oil is in the pipes at that sooo wiped as much off as i could buy will just have to let the rest burn out i guess Quote
