Right I have a JAM FCC fitted to my car and it was installed before I bought it. The problem is im only able to run 13psi before my glanza hits fuel cut so the FCC cant be working! I have taken the glovebox out and checked all the wiring going into the ecu, all looks fine, soldered properly, no amateur job. The wiring is wired up to exactly the same wires as you would wire a HKS FCD to. Is this correct for the JAM FCC as I thought they were different? Does anyone know where I can get some info on this and maybe even a wiring diagram? Any help would be much apprectiated as this is doing my tits in now!!! Thanks :)
Yeah, it goes to the live, the earth and the the green and white wire from the FCC splises inbetween the boost wire or whatever it is? So if its wired up right what acn it be? Why is it not working??
Think im just going to have to buy a HKS FCD and re-wire it! Must be the FCC that screwed!! unless anybody knows anything else?
