Bilkok Posted October 4, 2007 Posted October 4, 2007 hi all, im a bit of a newbie... I have just got a set of clear indicators for my starlet and i just tried fitting them to the car.Do you need to remove the headlights to get the indicators out? i have taken the only screw i can find that holds them on just iniside the engine bay but it seems really stuck like there are more screws holding it on. I dont want to pull it too hard incase i rip the wires out...thanks in advance for your help! Bilko Quote
paul w Posted October 4, 2007 Posted October 4, 2007 I take it you mean for an EP82?If so undo the screw and give the unit a whack with your hand on the sticky out bit toward sthe front of the car.It'll pop right out. Quote
Bilkok Posted October 5, 2007 Author Posted October 5, 2007 Cheers matey Ill try it when i get up and let yous know if i rip the wiring right out!Thanks Quote
Bilkok Posted October 5, 2007 Author Posted October 5, 2007 Im very concerned people !!!!Please look at these photos....http://s238.photobucket.com/albums/ff132/ep82_photos/I undone the only screw inside the engine bay and gave it a good hard knock as instructed toIf you look at photos DCS00094 you can see that the side of the light is all scratched where i pulled it and also in DSC00096 you can see on the new unit that there is a lip on the bottom thats appears to go behind the bumper.I really dont want to pull it anymore cause to get it out as far as photo DSC00094 the front wing panel moved/bent a bit.Help please !!!!!! Quote
Ryno Posted October 5, 2007 Posted October 5, 2007 can't see the pics bud! if it's an EP82....basicly once you've un-screwed it and un-plugged it, the only thing holding it in is a ball socket that should just pop straight out with a little force cup the indicator in your hand and push forward Quote
Bilkok Posted October 6, 2007 Author Posted October 6, 2007 http://i238.photobucket.com/albums/ff132/e...os/DSC00093.jpghttp://i238.photobucket.com/albums/ff132/e...os/DSC00094.jpghttp://i238.photobucket.com/albums/ff132/e...os/DSC00095.jpghttp://i238.photobucket.com/albums/ff132/e...os/DSC00096.jpghttp://i238.photobucket.com/albums/ff132/e...os/DSC00097.jpgHopefully that might work for you guys to see, if not then f**k it. Ill have another go at it later onThanks Quote
shelly_star Posted October 6, 2007 Posted October 6, 2007 welcome to UKSC Oh my goodness what have u done to the indicator?! mine on the EP91 was just unscrew and take out like Ryno says easy job. Quote
Ryno Posted October 6, 2007 Posted October 6, 2007 dunno how you've managed to dent and scratch that just pops out, see that little metal bit on the bottem right of pic DSC00097thats the ball bit thats holding the hole lot in and should just pop out!as you push forward, try giving it a wiggle like i said, cup the lense in your hand so you don't crack it! Quote
