Sandham Posted August 14, 2013 Share Posted August 14, 2013 (edited) Is it possible to have my standard ep82 ecu remapped to run a td04 instead of emanage ect?And would i still need my fpr and fcd? Edited August 14, 2013 by Sandham Quote Link to post Share on other sites
Weyro Posted August 14, 2013 Share Posted August 14, 2013 the standard ECU cannot be remapped, you need some form of piggyback like emanage or a standalone ecu like OMEX to get a proper "mapped" setup. but many people run the td04 using an fcd and fpr, including myself (technically i use a fuel controller, which is just a fancy fcd really) Quote Link to post Share on other sites
Sandham Posted August 15, 2013 Author Share Posted August 15, 2013 Ok thats good news then, so just set the fpr using a wideband? Im only planning on 1 bar boost for now Quote Link to post Share on other sites
Weyro Posted August 15, 2013 Share Posted August 15, 2013 to do it properly you would want the fueling set up on a rolling road with some way of detecting detonation (det cans), and a wideband for measuring the afr Quote Link to post Share on other sites
Sandham Posted August 15, 2013 Author Share Posted August 15, 2013 Ok thanks Quote Link to post Share on other sites
