Collins611 Posted August 15, 2013 Posted August 15, 2013 Alright peeps I have a standard internals I'm currently running td04With FcdFuel pressure reg set at 45psi (This is only temp until November when I get greddy blue)I have a single core civic rad And just had delivered my 1bar actuator Is it save to run a bar on this rad an what sort of power will I put out Currently my actuator can only do 0.7CheersDan Quote
PaulStarletSR Posted August 15, 2013 Posted August 15, 2013 hard to tell unless u list full mod spec but unmapped your probly gona be anywhere between 160-190bhp at best i reckon. mapped ul see 210-230bhp safely Quote
Taggy Posted August 15, 2013 Posted August 15, 2013 (edited) Yeah thats fine on the radiator, i would be more worried about ensuring your not still using the standard manifold, its got a restriction in one of the runners which means if you crank the boost up past standard without either removing restriction or upgrading manifold it will melt a piston. Also to run more than standard boost you need to get your fueling setup correct, you cant do it just by the psi on the regulator as every car is different, you either need to do it with a rolling road session or using a wideband air/fuel ratio sensor. dont fuck around with it until you have done this read the wiki file on how to get 200hp safely guide on here by socks Edited August 15, 2013 by Taggy Quote
PaulStarletSR Posted August 15, 2013 Posted August 15, 2013 Yeah thats fine on the radiator, i would be more worried about ensuring your not still using the standard manifold, its got a restriction in one of the runners which means if you crank the boost up past standard without either removing restriction or upgrading manifold it will melt a piston. Also to run more than standard boost you need to get your fueling setup correct, you cant do it just by the psi on the regulator as every car is different, you either need to do it with a rolling road session or using a wideband air/fuel ratio sensor. dont fuck around with it until you have done this read the wiki file on how to get 200hp safely guide on here by socks hes runnin a td04 mate, no ct9 Quote
har-vey Posted August 15, 2013 Posted August 15, 2013 i would stay at 0.7 bar untill you get the blue fitted but. stay safe. once blue is on get it mapped and go up to 1 bar depending on your setup you will be around 220-230 on average but with a healthy engine can see upto 250 Quote
Collins611 Posted August 15, 2013 Author Posted August 15, 2013 Cheers for the quick response I have stainless stell manifold Td04 braided oil water lines Stainless steel 3" decat into 3" rsr exhaust FmicRelocated filter New belts pumps etcUpdated 225 fuel pump FcdFuel pressure reg New clutch + bearing Many be more like I've had 3 glanza so I know altitude about them Just wanted advice as this is my first td04 Others were hybrids etc Quote
