As above just on with the engine swap and i have time to go through all the plugs and tidy everything up, retape and rewire stuff if neccesary, Tried a search but to no avail about removing stuff
Can i remove the standard glanza boost solenoid? Im wanting to cut the plug off and tape the loom up.
Also when the ABS is coming out, can i remove all these plugs and do the same?
And last of all the charcoal canister, when i have removed this im assuming people just put little one way breathers on like on motorbikes? and can i also remove the plug and little blue box and tape the loom up also?
Just want to go through the full loom and remove everything unnecesary, freshly tape it all up and tuck some of it if possible
On this photo can i remove the blue plug and valve it plugs into?
And in this photo can i remove the plugs and solenoid shown?
Thanks
the pictures, sorry didn't read the rest.
Can leave charcoal to vent to atmosphere I used a long hose routed into side of wing.
I removed all the plugs on unused sensors etc, never had any issues!
Thanks mate, All the plugs in the photo bar the coil pack one obviously lol can all go? No fault codes, engine lights or anything? If the car still ran i would unplug them and try it but can do that lol
And all 4 plugs on the abs pump can go?
If your removing abs, strip the lot out yeah, others have done so.
I removed all but the abs on mine I never got any warnings, keep the plugs just incase, I sold my car but I have the plugs still lol.
