Hi guys
My head is cracked around one of my exhaust manifold studs and is leaking a tiny bit of oil. would this cause the exhaus to smoke a little on start up or is it likely to be the valve stem seals?
I have a spare head a brand new head gasket and brand new stem seals what else would i require to change the head? Also how hard of a job is it?
cheers
kez
its not a hard job,you need headbolts also as these are not reuseable mate.
to replace with new stem seals you need valve spring compressor.
Edited by mikey4410
