PWG123 Posted August 22, 2013 Posted August 22, 2013 I've only had my Starlet two weeks. It was absolutely fine started fine, the crap manifold the previous owner put on cracked and then split, i then came out the next morning to start it and it struggled to start, would only run on its own power, as soon as you gave it throttle it tried to die after 3 - 5 mins it's fine. I stopped driving it after this. I've now replaced with a Zisco (which the gasket hasn't seated and is still blowing). and still has the starting problem. also the engine management came on When the manifold split I guessed it was the O2 Sensor. Help would be appreciated as I'm pissed off at havingthe car two weeks and it has problems. cheerspete Quote
Chesh Posted August 22, 2013 Posted August 22, 2013 Have you checked spark plugs,dizzy fuel pump Quote
PWG123 Posted August 22, 2013 Author Posted August 22, 2013 Have you checked spark plugs,dizzy fuel pumpit only does it from cold, as soon as it's warm turns first time on the key. like it used to. But I'll check them. Quote
PWG123 Posted August 22, 2013 Author Posted August 22, 2013 anybody know what the problem could be? Quote
Danza V Posted August 23, 2013 Posted August 23, 2013 Could as above be the plugs, rotor arm etc.. Take the plugs out and have a look, same with the rotor arm and contacts on the dizzy. Quote
yaristurbo Posted August 23, 2013 Posted August 23, 2013 water temp switch or wiring mine was same look at right hand side of clyinder head there a few sensors there, my wiring had snapped off due to age Quote
Danza V Posted August 24, 2013 Posted August 24, 2013 I thought that if the water sensor is disconnected it doesn't start at all? I had that when I broke mine lol.. Quote
PWG123 Posted August 25, 2013 Author Posted August 25, 2013 it was the water temp sensor earth wire had snapped. Thanks for the help . starts first time now Quote
