Struggling to start EP91.
a crak in the mani wouldnt casue eng light to come on ?
for starting its ignition new spark plugs and leads maybe a dissy
cheers Thanks for replying.
but it's weird tho you have to switch key turn key off, switch key turn key off about ten times it'll run but be lumpy and if you give it throttle it tries to die, give it two - three minutes on its own power and then it's fine. Only does it from cold start, as soon as it's warm starts first time.
manifold does need sealing but I'm waiting on parts.
cheers
pete
