jayc-glanza17 Posted August 24, 2013 Posted August 24, 2013 buy 19mm diameter oil pipe from a local shop bud, much cheaper then a specific one.
EPnick22 Posted August 24, 2013 Author Posted August 24, 2013 its different size each end of the pipe dude
mikey4410 Posted August 24, 2013 Posted August 24, 2013 http://www.ebay.co.uk/itm/330650756290?var=540049575987&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649Just fitted up this on me newly fitted td04.this is a little big but a jubilee clip takes up the slack fine.no leaks at all.Bought this as i heard the rubber ones perish and leak oil.
EPnick22 Posted August 24, 2013 Author Posted August 24, 2013 just bought a silicone one from glanza-ben, so im sorted now, and mikey you got the turbo all on now then?
mikey4410 Posted August 24, 2013 Posted August 24, 2013 Cool man.yeap all sorted,actuator modified turbo stripped to the core ,housing re-postioned/pointing to the floor.didnt take long.Just need front mount now
EPnick22 Posted August 24, 2013 Author Posted August 24, 2013 what did you use for the snap ring? having trouble as you know when i told you the other day lol
mikey4410 Posted August 24, 2013 Posted August 24, 2013 Lock rings easy with the right tool as u can imagine.I used cheap pair of long nose pliers and bent the ends inwards slightly to near "hooks" You will do it first time with the pliers like that and also the help of a strong small flat head
EPnick22 Posted August 24, 2013 Author Posted August 24, 2013 gunna go attempt it now mate you getting you car dyno tuned or anything after?
mikey4410 Posted August 24, 2013 Posted August 24, 2013 nope no need,got wideband etc.not worried about what power it makes either,just want it quicker than 70 bhp which i know it will be
EPnick22 Posted August 24, 2013 Author Posted August 24, 2013 70 lol? im sure itd be quicker than that without the turbo haha
mikey4410 Posted August 24, 2013 Posted August 24, 2013 thats what im getting at ,standard n/a power is 70 and i know its gona be a bit more than that .lol
