zrp con rods
Hi just wondering if anyone has any experience with these rods and how they have been rated there is a forged package on sale ebay which I thought was reasonable price spec as follows
Starlet 1300 turbo Ultimate engine rebuild kit
This kit includes,
Wossner forged piston set (rings,pins and clips included) available in 74mm 74.5mm and 75mm bore sizes (please state when ordering)
ZRP forged connecting rod set fitted with ARP 2000 fasteners and rated to over 600 bhp on 4 cylinder engines.
Athena MLS steel headgasket available in 1.2mm or 1.4mm (please state when ordering)
ACL main bearing set and thrust washer set at std size
Calico coated ACL big end bearing set (these are the ultimate performance bearings with high lubrication coating for extreme performance)
For any info required you can contact us on 01278 453036
The ZRP con rods are a sub-division os Wossner I believe, much like PEC, so quality should be pretty good.
I'm not the biggest fan of Wossner pistons though, but there's too much detail to go into for this thread as its down to the piston design.
