Sparky Posted October 10, 2007 Posted October 10, 2007 Anyone got a write up or information/ problems on the Starlet brakes I could see??? Thanks Lewis Quote
Guest Enzo Posted October 10, 2007 Posted October 10, 2007 what information are you looking for specificaly bud? Quote
Blue Icarian Wings Posted October 10, 2007 Posted October 10, 2007 I've gathered from here, that early ep91 brakes are small and attached to the hub, later ones are on calliper-carriers, so will require matching hubs if you want stick them on the early ep91's.The later ep91 brakes are the same as Glanza ones.The rear disc brakes from Glanza/GT Turbo's can be put straight on.Levin ones can be done but are a pain (same size disc but wider I believe?).Recommended upgrade is disc and pads, followed braided brake lines then master-cylinder brace.There are guides here and on TGTT about changing bits and swapping them over.Can't think of any problems that just starlets have.I'd quite like to know how Paseo brakes compare to ep91 brakes (I'd bet the same as later ep91's but would nice if they were bigger ) would also be nice know about the brakes from the Corolla that has the 4E-FE engine too. Quote
Sparky Posted October 14, 2007 Author Posted October 14, 2007 Need to know sizes thickness and centre bore etc and maybe the materials used and other bits and pieces for my project Quote
riko666 Posted October 14, 2007 Posted October 14, 2007 I'm using Glanza discs on mine so unfortunately they don't come in bigger sizes.Off the top of my head the 2 sizes on the Starlet GT's/Glanza's/Paseo's/Cynos's were 236mm and 254mm discs, both 19mm thick, the earlier cars having a 52mm Center Bore the later cars the 54mm bore. Both probably made of cast steel.A major problem is that the rear calipers like to seize, be it by corrosion of the pin, or deterioration of the seals etc...Especially if the handbrake is left up for extended periods of time Quote
Sparky Posted October 14, 2007 Author Posted October 14, 2007 Nice one Riko, any idea if the n/a discs are the same size as GT etc?My project is designing uprated discs for the Starlet but some caliper and pad info wouldnt do no harm Quote
potge Posted October 14, 2007 Posted October 14, 2007 That was perfect on every aspect. Thanks for your time and the share of knowledge especially on the least known conversions. thanks again Quote
Blue Icarian Wings Posted October 14, 2007 Posted October 14, 2007 I think I just wet myself Always wanted to know what brakes could be applied from other cars, one question, we share a PCD with the some Mazda's (323, MX5) the discs will fit, I wonder about the rest, or is it a case of wrong bore,....Great write up man Quote
Guest Enzo Posted October 15, 2007 Posted October 15, 2007 thanx guys il be taking it down after sparky sees it, its just a hint of whats gona be on the site,the info will be displayed in a much cooler way.@wingsit would be a case of different bores and stud pcd of the hubs but ive done alot of research and these are only the real ones that fit, im trying to find other calipers that share the same mounting hole width, but thanx for the coments Quote
Sparky Posted October 15, 2007 Author Posted October 15, 2007 Interesting read Geo mate ;)Appreciate it Just a taste of things to come guys, I'm looking forward to the rest of it Slim's brake set up looks the nuts, anyone heard off him lately? Quote
