lookout_5-0 Posted August 27, 2013 Share Posted August 27, 2013 Hijust about to get my 97 4efe starlet MOT'd and there quiet a lot of light blue / grey smoke on start up but disperes a grey smoke after its warmed upits only done 62k and was sat for a couple of yearsoil change filter etc done and i was wondering if there might be a breather pipe and where this is.I'm just trying to rule out everything before getting the vavle seals doneCheersK Quote Link to post Share on other sites
rmsnoel Posted August 27, 2013 Share Posted August 27, 2013 The breather pipe is plain to be seen on top of the rocker cover attached to the intake manifold. M14bolt blocks it nicely..If your doing the seals you could fit the skinny headgasket saying as your car is such low miles, fte valve springs are very cheap secondhand and you would revvy wee beast when your finished Quote Link to post Share on other sites
