When on first ignition the engine light doesn't show, also no fuel Coming from the pipe that goes into the fuel rail when turning over. What should I check? Could it be the fuel pump? Or maybe a fuse?
Mine did this earlier his year and after looking through a load of things turned out the actual main efi relay had gone, the fuse was still fine though
