Evo_stevo Posted August 28, 2013 Posted August 28, 2013 (edited) Can anybody help me out with a couple of plugs from a glanza wire loom.I'm after the plug and a couple of cm of wire for the OIL PRESSURE switch from the loom.Also the plug and a couple of cm of wire for the COOLANT TEMP SENSOR also from the loom.And a Pcv valve the 1 on the top of the rocker cover also the grommet to fit it if possible.Let me know what you have with a price posted please.Or does anyone know if these plugs are the same on other toyota's which would help my search aswell Thanks in advance Edited August 28, 2013 by Evo_stevo
