sosolid Posted August 29, 2013 Posted August 29, 2013 my glanza has becaome really laggy when it warms up. when cold it dives normal but when it warms up i flaw it nothing den suddenly da power kicks in and im off. isit da turbo? or sumtin else. Quote
Mr. Chem Posted August 29, 2013 Posted August 29, 2013 Could be an exhaust leak from the manifold or turbo? Is the manifold cracked at all?The heat from the exhaust could be causing the crack to open when hot, which may be why it's ok when cold. Quote
sosolid Posted August 29, 2013 Author Posted August 29, 2013 the mani is standard cast iron but ive got a decat on. so cud it be dat? Quote
sosolid Posted August 29, 2013 Author Posted August 29, 2013 also is it normal for the pcv valve to be hve sum misting of oil around the top where the rubber hose from the intake connects to it? Quote
