theminiguru Posted September 4, 2013 Posted September 4, 2013 hi guys, im just trying to get some clarity on an issue with me car and im hoping someone can shed some light on what it could possibly be?its a pain to try and describe but here goes..... basically it doesnt do it all the time but once its done it once it wants to do it often, ill be driving smooth changing gears between 3000-4000 revs then all of a sudden ill put the clutch in and the revs will not drop and hold for a couple of seconds before dropping down. at this point it is stiff to get it into the gear? it feels like the car is braking ever so slightly via the clutch? ive had a new slave cylinder fitted with new fluid and its not that so im stuck for ideas? it is a 6 paddle Spec clutch and its done about 8000 miles. any help is always massivly appreciated as always Quote
yaristurbo Posted September 4, 2013 Posted September 4, 2013 any signs of fluid from master clyinder on bulk head or inside basically check all the hydralic system and if its not that then time to have box out mate and see whats lurking Quote
