Bean Posted October 14, 2007 Posted October 14, 2007 well my gt hasnt been running right recently. seems to have been miss firing and holding back now and again and i also had a vacuume leak where a t piece broke. i replaced the t piece and i had slightly more vacuume back than i lost, so that was fixed and the missfiring i think my have been due to a loose wire on my safc2?? So i did the diagnostic check and i have a code: 25 lean signal 31 AFS (where fitted) open circuit in VC, VS, VB or short circuit in VC or Map (where fitted) open circuit in map or short circuit in VC?? if im right afs is air flow sensor is it not? could the code 31 be due to my broken vacuume t piece that i have now fixed?? Please help me guys, Quote
Bean Posted October 20, 2007 Author Posted October 20, 2007 Well my code 25 has gone but i still have the code 31 has anyone got any ideas? im going to have to take it to a garage unless anyone can help. Quote
Tintin_SR Posted October 21, 2007 Posted October 21, 2007 Well my code 25 has gone but i still have the code 31 has anyone got any ideas? I'm going to have to take it to a garage unless anyone can help.check your ideal-control valve Quote
Bean Posted October 21, 2007 Author Posted October 21, 2007 check your ideal-control valveThanks for the reply, could you go into a bit more detail please mate. i thought it might be to do with my hks fcd so i found that under the dash and made sure the wires were all ok. Quote
Tintin_SR Posted October 21, 2007 Posted October 21, 2007 Thanks for the reply, could you go into a bit more detail please mate. i thought it might be to do with my hks fcd so i found that under the dash and made sure the wires were all ok.what dus your car do when in hight revs and you let off but not all the way just half power? what dus it sound like ?? Quote
Bean Posted January 7, 2008 Author Posted January 7, 2008 what dus your car do when in hight revs and you let off but not all the way just half power? what dus it sound like ??Was just looking through some threads and saw this. The engine management light hasnt came back on for ages now, but it does still fuel cut if i floor it. i bought a jam fcc to replace the hks fcd but i think im just going to get an apexi power fc and get it mapped. Quote
