Sandham Posted September 10, 2013 Posted September 10, 2013 Hi, converting to td04 and im just wondering wether i need to use a fpr when using a emanage blue or i can remove it? Also can i remove my fcd? Quote
AdamB Posted September 11, 2013 Posted September 11, 2013 Keep the FPR. They are a good tuning tool and allow the tuner to maximise your fueling system. Quote
Sandham Posted September 11, 2013 Author Posted September 11, 2013 Ive bought a emanage already mapped to run a td04 at 0.9 bar so i dont know what pressure id need to run it at? Im planning on getting a map for my car asap but until i can afford it i was going to run it as is Quote
AdamB Posted September 13, 2013 Posted September 13, 2013 That wouldn't be wise, every engine is different and take different amounts of ignition advance and fueling. Quote
TurboTobz Posted September 13, 2013 Posted September 13, 2013 get the map done for your car, keept the fpr and save for the mapping while running the fcd, or even safer would be to run under fuel cut boost and sell that fcd and put the pennies towards some map time Quote
