tatep82 Posted September 11, 2013 Posted September 11, 2013 has anyone got a emanage blue or just the harness to fit a glanza v,td04 front mount intercooler pipe work,sard fprtd04 turbooil linesarifilter relocation kit thanks matt
Fro Posted September 11, 2013 Posted September 11, 2013 Assuming you are running a ct9, Do you have a front mount already?If you do and your kit looks anything like this, you can slightly modify the pipe circled red an it should fit between your rotated td04 and the bend off your cooler.
tatep82 Posted September 12, 2013 Author Posted September 12, 2013 Hi mate yes I am running a ct9. I have a hdi fmic Will I be ok without changing my pipework on that kit? Matt
Fro Posted September 12, 2013 Posted September 12, 2013 Ah ok, the hdi kit has the "short route" piping that goes down by the power steering pump so you won't have that pipe. Cant remember where the bend off the cooler stops on the hdi kit but your probably as well with a couple silicone bends and a joiner in between. Unless the bend coming off your cooler lands pretty close to the turbo outlet you might get away with just one. Hope that makes sense, been a long night at work!
