Noise And Dropping Revs With Clutch (Video Added)
Firstly it only started when i was coming into around about high enough in the revs
when its cold its not as bad but you can hear the noise more, when it warms up it gets worse but the noise isn as bad
if you hold it long enough it will cut out
or while changen gear it drops too and cuts out when comeing to stop
has anyone come across this problem before ?
http://www.youtube.com/watch?v=SLw2qVTRDUI&feature=youtu.be
I had a act that did this all I could work out is slowing the crank dude to force needed to compress the clutch fingers
Had that noise to
yeah after doing sum reading i tink this could be it but it wasnt always like this
How did you stop it ?
Edited by FrancyGlanza
