just received my rods from Mike @ TD today, happy days!! :D is there a direction for the rod or does it matter? also theres no oil holes in the big ends? how does the oil reach the shells to lube them?!
why are u worrying again !! they are £400 quid rods and they work.lol.end of
if both sides are the same then they go anyway.cant remeber if my pecs were different or not
Edited by mikey4410
could have got you your scat rods with the pistons and everything else mate ;)
Yes there is a correct orientation. If you look on journal the notches that locate the bearings on a clockwise rotational engine these go on the exhaust side of the engine. Its all to do with bearing loading on rotational thrust
Tim
TB Developments
well you know i'm here to help if i can. Wish you'd have let me build the engine properly from the start ;) would have used the 74.5mm and then used the torque block to correct for the factory relaxed block bore and honing.
Tim
TB Developments
well not as much as if you get this wrong and then have to rebuild it again ;) engine building to a proper level isn't just spanners and screwing things together. Alot of people don't realise that
i know, im not just bolting it all together and hoping for the best its all being done how it should cause my dad used to build engines, but hes not as clued up related to the math that youre going through to calculate the head gasket thickness etc, If i had the money to do it all in one I wouldve but sadly i work part time while at college so every month i get some money together for each set of parts i need
