Ok guys, I've also managed to get my hands on some Kleers detailing products so I'm doing some detailing packs with a decent saving. There are a few different packs as I have a mix of products. Some of the bottles have a couple of dings but nothing major and the products themselves are good.
Here is the stock I have and I will do packs in any configuration you like as long as you have at least 3 products together including free shipping within the UK:
Kleers The Car Shampoo - RRP £13.00 @ £11.00 each - 4 left
Kleers The Glass Cleaner - RRP £7.00 @ £5.00 each - 6 left
Kleers The Paint Detailer - RRP £13.00 @ £11.00 each - 1 left
Kleers The Metal Polish - RRP £8.99 @ £7.00 each - 4 left
Kleers Microfibre Mist Spray - RRP £10.00 @ £8.00 each - 3 left
Kleers The Paint Cleaner - RRP £7.99 @ £6.00 each - 3 left
Kleers The Silver Interior Purifier - RRP £14.99 @ £12.00 each - 8 left
Kleers The Supersoft Polish Towels - RRP £5.50 @ £4.00 each - 4 left
Kleers The Soapy Detailing Cloths - RRP £4.99 @ £4.00 each - 9 left
Here is some information on the products:
Large 500ml bottle with pump action dispenser to ensure a correct amount per bucket - saving product and giving consistency each time.
Kleers understands what customers want from a car shampoo and has created an easy-to-use, low-foam, quick-rinse formula that has excellent cleansing properties and reduces the likelihood of water marking.
Its ease of application, either by hand or via pressure washer, will save users time and money, whilst consistently achieve excellent results. The aluminium bottle with a push-to-dispense top allows for accurate measures to be used.
Approximately 25 washes is possible from its 500ml contents depending on dilution.
250ml bottle with small pump action head - spray pattern, enabling quick and easy application in tight spots.
A car will always look better with clean windows – from inside and out.
There are many glass cleaning products on the market, but few developed specifically for automotive applications. That’s why many are difficult to use, as they do not clean affectively and leave smears or streaks. As well as the aesthetic implications, this can also be distracting to drivers, especially at night.
Kleers The Glass Cleaner produces a crystal clear finish for both the inner and outer surfaces. For best results, we recommend using this product together with a Kleers Glass Cloth.
Kleers Soapy detailing Cloths - RRP £4.99
KleersSoapyDetailingCloths_zpsc45e77d6.j
1 pack which contains 4 large soapy cloths. Each cloth can be cut into 4 for amazing value and cleaning.
Supplied as a pack of four, these handy preimpregnated cloths simply require dipping in a clean bucket water and watch them come alive.
Once wet, this durable and tough disposable cloth will discharge a powerful soapy lather that helps remove dirt and grime and can be used instead of ruining a sponge, mitt or chamois.
Ideal for areas that are inherently dirty, such as: wheels, under body sills, tail pipes and the engine compartment - all the mucky areas that require deep cleaning without ruining your bodywork cloths/sponge or mitts.
Once used, simply throw them away.
As a guide one large cloth can be cut into 4 and each of the sections is sufficient to cleaning one wheel with vigour.
Kleers Supersoft Polish Towels - RRP £5.50.
1 pack containing 6 large cloths - super soft and disposable to prevent scratching.
An ideal partner to any of the Kleers wax, detailing and cleaning range, Supersoft Polish Towels are manufactured in the UK from a highly absorbent, non-woven, spun-laced fabric, that produces a fine, supersoft cloth. This distinctly specified composition provides a top quality product that reduces the possibility of scratching and makes it easier to achieve perfect results.
Kleers The Metal Polish - RRP £8.99.
250ml aluminum tin with screw lid and inner gasket
The ultimate metal polish - suitable for all metal types including precious metals - stunning results with little effort.
Unique protecting layer to prevent future surface deterioration and corrosion after use.
A big hit with classic and historic car owners, Kleers The Metal Polish is a highly effective soft paste, supplied in a traditional style container that can be used on chrome, stainless steel, aluminium and even soft metals such as copper and brass.
Even though a only small amount needs to be used for each application, the result is impressive – particularly on tarnished surfaces.
For best results, we recommend using this product with Kleers Supersoft Polish Towels
Potential uses :
Exhaust headers, chrome exterior parts, wheels, window trims, engine bay components - superb on motorcycles and trucks
Kleers The Paint Cleaner - RRP £7.99.
250ml bottle with pump action dispenser for accurate application
Use The Paint Cleaner to repair minor blemishes in your paint finish [ swirls and marks ] and clean the paint surface prior to applying The Finishing Wax.
As well as helping to remove super-fine scratches, scuffs, blemishes and deal with discoloured or tarnished paintwork, it will not leave marks on rubber or plastic components - the more work you put in, the better your results will be.
Because it doesn’t smear or generate dust, it saves time and requires less effort to achieve good results. As well as being an ideal preparation in advance of applying Kleers The Finishing Wax, The Paint Cleaner is a mild polish.
Suitable for both hand or machine polishing and bodyshop safe as it has no airborne silicone particles.
We recommend that you treat your vehicle a full paint cleanse once a year and is followed up by periodical applications of The Finishing Wax
Please apply this product using The Supersoft Polish Towel, alternatively use a microfibre cloth.
Kleers The Microfibre Mist Spray - RRP £10.00.
KleersMicrofibreMistSpray_zps3d69926c.jp
Large 500ml bottle with mist and spray tigger functions for ease of use.
Perfect for cleaning and maintaining car wraps and vinyl which has been laquer protected
Designed mainly for use after waxing and when paintwork is clean, this easy to apply spray is ideal for ensuring that any residue or unwanted marks are removed where quick detailing is required, leaving a just waxed shine.
Also great as a clay bar lubricant fro detailers.
Simple to use, spray on a mist of product to paintwork and windows and buff to a dry shine using a microfibre cloth.
Best applied using a Kleers Microfibre Finishing Cloth, the spray does not contain silicone and therefore is safe to use on all areas of your car body and windows - bodyshop safe and perfect to use at indoor events.
We recommend the spray is not used on ink-printed vinyl stickers as it can remove the ink in certain circumstances
Kleers The Silver Interior Purifier - RRP £14.99.
KleersSilverInteriorPurifier_zps192ee820
150ml aerosol can with captive application nozzle for one-time use inside your vehicle.
While traditional air fresheners do their best to overcome odours that ingress the passenger compartment, it is unlikely they will last for long or kill any of the bacteria that is often the cause of unwanted smells.
Kleers innovative The Silver Interior Purifier spray does just this and targets the bacteria at source, whether generated by animals, cigarettes, food or damp - it penetrates your heater and air conditioning pipework and systems as well as all interior surfaces in your vehicle.
One can equals one treatment and remains effective for up to six months - simple leave your engine running, close all windows and doors, put the air conditioning on full recirculate [ or heater on full if you don't have air-con ], push the captive lid and allow the can to disperse its entire contents into the air and surfaces of your car interior.
Leave your air-con or heaters on full for 15 minutes and then open your car and leave to naturally air dry after wiping up any excess product.
The result will be a fresh, clean and bacteria-free environment within your car and all air systems.
Not to be confused with air fresheners or sprays which hide smells - our product contains Silver Ion which kills the bacteria that cause the smells, it does not mask them.
Kleers The Paint Detailer - RRP £13.00.
Large 500ml can with trigger spray featuring spray or mist functions.
The ultimate detailer, superior gloss and ease of use for amazing results.
An easy way to bring back the shine is by using Kleers The Paint Detailer.
Rather than going through the complete waxing process, simply mist a light application over the car’s paintwork and using a microfibre cloth, buff to an incredible glossy shine with this innovative detailer solution, is all that’s needed to restore that ‘just-polished’ look.
It also serves to remove any stray watermarks that might have remained after washing and is an ideal lubricant for a clay bar.
This product is non-smearing and safe to use on rubber and plastic components
Contains silicone - not for use on windows or brakes - want a non-silicone based detailer? try The Microfibre Mist Spray
