sosolid Posted October 6, 2013 Posted October 6, 2013 changed all spark plugs. but still when the car has been driven it idle drops alot to .5rpm and goes back up to 1000rpm, its goes back and forth. is that a misfire??? Quote
nikhilkamdar12 Posted October 6, 2013 Posted October 6, 2013 Try changing the HT leads had the same problem when I first got mine. I just got the entire overhaul ignition kit kit from TD and it drives perfect now, no misfiring or stuttering Quote
daveEP Posted October 6, 2013 Posted October 6, 2013 Defo sounds like leads or dizzy cap mate. would change both for good mesure. Quote
sosolid Posted October 7, 2013 Author Posted October 7, 2013 could it be the throttle body position sensor? Quote
