Anglas Posted October 10, 2013 Share Posted October 10, 2013 (edited) Hello, I bought Starlet N/A. Got problems after I changed engine. When I turn key to ignition, there is no check engine light. And when i try to start engine, there is no spark and seems fuel pump doesn't work. Than I removed aftermarket alarm, but that not helps... I think there is problem with immobiliser, so how to remove/disconnect/disable immobiliser? Edited October 10, 2013 by Anglas Quote Link to post Share on other sites
