scottsmith96v Posted October 21, 2013 Posted October 21, 2013 Needing help on a 5e swap few questions ad like to through out their, if I have 5e fly wheel I can get away with using the 4e clutch box and shafts? Is the 5e plug and play into the 4e loom? What ecu can I run on it? 4e one work? Just till I wire in my good ecu before mapping? Thanks Quote
bucketep91 Posted October 21, 2013 Posted October 21, 2013 Taggy made great guide on building a 5e, check that out ;)You need to use the 3e flywheel to use a 4e clutch on a 5e, wiring will be pretty much the same and the 4e ecu ahould run it. Quote
scottsmith96v Posted October 21, 2013 Author Posted October 21, 2013 What it's a 5e flywheel and clutch? Then my 4e box that work? Quote
Fozzie Posted October 21, 2013 Posted October 21, 2013 It's 3E flywheel with 4E clutch, using the 4E box.The 4E clutch is 212mm and the 5E is 200mm, but you can't just put a 4E flywheel on a 5E engine because the bolt pattern is wrong. The 3E flywheel is also 212mm but uses the same bolt pattern as the 5E one Quote
scottsmith96v Posted October 21, 2013 Author Posted October 21, 2013 It's 3E flywheel with 4E clutch, using the 4E box.The 4E clutch is 212mm and the 5E is 200mm, but you can't just put a 4E flywheel on a 5E engine because the bolt pattern is wrong. The 3E flywheel is also 212mm but uses the same bolt pattern as the 5E one What's a 3e out off? Where can I get one Quote
Fozzie Posted October 21, 2013 Posted October 21, 2013 http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_101&products_id=311There you go chap Quote
scottsmith96v Posted October 21, 2013 Author Posted October 21, 2013 http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_101&products_id=311There you go chapThanks bud Quote
