Well it comes with the ignition and injector harnesses which you do want to get a better tune from it, ideally you also want the 3 bar map sensor other than that it's just a case of fitting (wiring in) and mapping.
It gives you more options then a P&P and if you're not looking for silly power then it will do the job fine over a stand alone, seeing as you're looking at Wallace Performance too it's a good option as Matty is happy to work with the Blue, it's what I'm running.
