Jrsalisbury Posted October 25, 2013 Posted October 25, 2013 Hi guys just replaced my old suspension with bc coilovers and after roughly 4 weeks I've got a knocking noise that you can feel in the pedals, had it down the garage and they can nothing wrong. Has anyone had the same problem or have a solution ?? Cheers Quote
rmsnoel Posted October 25, 2013 Posted October 25, 2013 Man there arent many bolts holding in the suspension. The two bolts at the bottom of the shock need tightened with a breaker bar or wheel brace. Then there are the four bolts up top that just need sweetened up with a spanner. Best advice is to take it back to the garage fpr if it was MOT time the knock would be found Quote
Jrsalisbury Posted October 25, 2013 Author Posted October 25, 2013 Ok cheers guys will give it a try see if it makes a difference ! Quote
