Anglas Posted October 29, 2013 Posted October 29, 2013 (edited) Please help After installing the new clutch, it doesn't want to release. Used this clutch: http://speedvisioncps.com/index.php?main_page=product_info&cPath=6&products_id=60Used new release bearing. Clutch cylinder bleeding done. Cylinder arm is moving at the gearbox. Edited October 29, 2013 by Anglas Quote
Broony Posted October 29, 2013 Posted October 29, 2013 Might sound daft but have you adjusted the clutch pedal in the footwell? If not did you install the clutch plate the correct way round . sorry if im teaching you to suck eggs Quote
Anglas Posted October 29, 2013 Author Posted October 29, 2013 Might sound daft but have you adjusted the clutch pedal in the footwell? Ohh, try to adjust it tommorow. Thank you! Quote
Anglas Posted October 29, 2013 Author Posted October 29, 2013 If not did you install the clutch plate the correct way round . Its possible to install the clutch plate the wrongway round? What a noob I am!!! Quote
Anglas Posted October 30, 2013 Author Posted October 30, 2013 (edited) Not possible to install the clutch plate the wrong way round. Now i will try to install stock pressure plate Edited October 30, 2013 by Anglas Quote
Anglas Posted October 30, 2013 Author Posted October 30, 2013 (edited) Not possible to install the clutch plate the wrong way round. Now i will try to install stock pressure plate Cluth working with stock pressure plate and aftermarket clutch plate Edited October 30, 2013 by Anglas Quote
Anglas Posted October 30, 2013 Author Posted October 30, 2013 Do you mean it wont go into gear? I installed this clutch kit: http://speedvisioncp...&products_id=60 and clutch always working, never releace. Then I change only pressure plate (Stock pressure plate + aftermarket clutch plate) and everything is working fine. (Not tested with high boost) Quote
