Kyle_R Posted October 31, 2013 Posted October 31, 2013 (edited) Iirc the rev counter is electronic so can only be the rev counter or wiring to it/from where signal is picked up(ecu I believe) so that's where to start your search for broken wires etc. take the clocks out nearly all the way and check plugs on back of clocks (could be a dry joint and a jiggle could sort the problem) if still no luck I have a rev counter here from a set I bought when I needed a fuel gauge. Hope that helps Edited October 31, 2013 by Kyle_R Quote
Bertie Posted November 7, 2013 Posted November 7, 2013 I have the same problem, but this happened after installing after market ecu - where is the signal wire on the Rev counter looked every where and could not resolve this. Heat gauge is all the way to the top - so we night have cut a common wire - can anyone help please. Thanks Bertie Quote
