gearbox oil overflow
why my gearbox oil came out (overflow) from speedo cable end (connected with gearbox) need you guide and assistance to fix this problem, i already tightened the cable. but still the oil overflow. need your guide and help to fix this problem.
thanks.
yeah on the ground mate. the leaking came out from the area of speedo meter end (i suspected). really wonder why.
Fyi, i just fitted a new Kaaz LSD Into my non LSD box.
Did i over filled the oil? i filled roughly about 2 litre...
