Chris_GlanzaV98 Posted November 11, 2013 Posted November 11, 2013 Anyone know the dimensions for the silicone pipe needed to connect the hot side to the turbo on tdo4 after its been cut ? If anyone knows the measurements of where to cht it would be great also Cheers in advance ! Quote
Chris_GlanzaV98 Posted November 11, 2013 Author Posted November 11, 2013 noone running a jp ic on tdo4 then nah ? Quote
ROTABOOST Posted November 11, 2013 Posted November 11, 2013 The compressor outlet is 48mm if that helps??? Just completed my conversion Quote
Chris_GlanzaV98 Posted November 11, 2013 Author Posted November 11, 2013 cheers bud much appreciated, hot side 48mm ? ill obviously size it up when it arrives just to get an idea you know Quote
ROTABOOST Posted November 11, 2013 Posted November 11, 2013 Yes mate the turbo outlet is 48mm so it would be a 48mm ID hose/joiner. Then a step up to the hot side of the IC Quote
Chris_GlanzaV98 Posted November 11, 2013 Author Posted November 11, 2013 thats 1.8 inch need to find the dimensions of the pipes and maybe get something custom made up to suit, wouldnt want to just clamp it on would prefer to force it over the turbo and then the silicone become wider so its a more snug fit Quote
