Zeldoz Posted November 14, 2013 Posted November 14, 2013 So this is probably an easy thing to do.. But history and starlet HT leads doesn't boad well with me. In my old rep 2 years ago i managed to snap the arm clean off the dizzy cap that the HT leads plug into.. Is there a technique to removing them? Just received my blue HT leads from Burny, and dont want a repeat of my last HT lead changeover!! Thanks Quote
Chris Green Posted November 14, 2013 Posted November 14, 2013 Yes, on the UK spec (can't see it being different on a FTE) you need to push the clips outwards. A small flat screwdriver will come in handy. Took me a while to figure it out. Quote
Zeldoz Posted November 14, 2013 Author Posted November 14, 2013 Yes, on the UK spec (can't see it being different on a FTE) you need to push the clips outwards. A small flat screwdriver will come in handy. Took me a while to figure it out. Screwy in underneath and gently pull out.. (off the arm?) Quote
Chris Green Posted November 14, 2013 Posted November 14, 2013 It's hard to explain in writing. On the actual clips there is another clip/tab it's usually point downwards. It is quite small but you pull it outwards and pull the big clip out, if you know what it mean. Quote
