Removing HT Leads - Broken them before.. Dont want to do it again..
So this is probably an easy thing to do..
But history and starlet HT leads doesn't boad well with me.
In my old rep 2 years ago i managed to snap the arm clean off the dizzy cap that the HT leads plug into..
Is there a technique to removing them? Just received my blue HT leads from Burny, and dont want a repeat of my last HT lead changeover!!
Thanks
Yes, on the UK spec (can't see it being different on a FTE) you need to push the clips outwards. A small flat screwdriver will come in handy.
Took me a while to figure it out.
Screwy in underneath and gently pull out.. (off the arm?)
