The fuse for the a/c is under the bonnet on the passanger side at the front, it has a/c printed on the cover for it so you can't miss it.
Thats his problem bud, his fuse layout diagram has gone walkies..
If you could, could you get a photo of youre fusebox diagram for him to look at ?
:D like a tube i noticed it before and forgot about it though was on our australian sister site and was in the diy section and there was a thread about a guy who had his aircon removed and was having similar problems and it said on it that this plug in the pics below,"from mine",the wire connections need to be bridged not wanting to run out and try it but does anyone have any first hand knowledge of this.
It is not actually in the fuse board, if you look under the bonnet as you are looking at the car, to the right hand side of the washer bottle under the wing the fuse for the A/C is situated there.
yes i know its in the second pic right hand side,there is two relays in there which one do i remove.
i bridged the terminals in that pic stopped my rad fan from being on constant but ran diagnostic and still getting error code 51.
and still idling quite high at about 1400 was nearer 2000.
Oh i dont know then mate i thought you just wanted to know where the fuses was. I have left mine so it runs constantly, therefore cooling the engine all the time.
there is a sensor u take out when you remove your aircon and are meant to leave it plugged in there to save any of these probs occouring!
and i'm guessing thats the plug in the pics in which you bridge the wires, which i have done.
and i'm still getting the error code 51.
