BoostJunkie Posted November 2, 2007 Share Posted November 2, 2007 does anyone know which fuse is the A/C fuse ?Thank You. Quote Link to post Share on other sites
jon5698 Posted November 3, 2007 Share Posted November 3, 2007 The fuse for the a/c is under the bonnet on the passanger side at the front, it has a/c printed on the cover for it so you can't miss it. Quote Link to post Share on other sites
Glanza_Ragger Posted November 3, 2007 Share Posted November 3, 2007 The fuse for the a/c is under the bonnet on the passanger side at the front, it has a/c printed on the cover for it so you can't miss it.Thats his problem bud, his fuse layout diagram has gone walkies..If you could, could you get a photo of youre fusebox diagram for him to look at ? Quote Link to post Share on other sites
BoostJunkie Posted November 3, 2007 Author Share Posted November 3, 2007 like a tube i noticed it before and forgot about it though was on our australian sister site and was in the diy section and there was a thread about a guy who had his aircon removed and was having similar problems and it said on it that this plug in the pics below,"from mine",the wire connections need to be bridged not wanting to run out and try it but does anyone have any first hand knowledge of this. Quote Link to post Share on other sites
jon5698 Posted November 3, 2007 Share Posted November 3, 2007 It is not actually in the fuse board, if you look under the bonnet as you are looking at the car, to the right hand side of the washer bottle under the wing the fuse for the A/C is situated there. Quote Link to post Share on other sites
BoostJunkie Posted November 3, 2007 Author Share Posted November 3, 2007 yes i know its in the second pic right hand side,there is two relays in there which one do i remove.i bridged the terminals in that pic stopped my rad fan from being on constant but ran diagnostic and still getting error code 51.and still idling quite high at about 1400 was nearer 2000. Quote Link to post Share on other sites
jon5698 Posted November 3, 2007 Share Posted November 3, 2007 Oh i dont know then mate i thought you just wanted to know where the fuses was. I have left mine so it runs constantly, therefore cooling the engine all the time. Quote Link to post Share on other sites
smythy75 Posted November 3, 2007 Share Posted November 3, 2007 there is a sensor u take out when you remove your aircon and are meant to leave it plugged in there to save any of these probs occouring! Quote Link to post Share on other sites
BoostJunkie Posted November 3, 2007 Author Share Posted November 3, 2007 so your rad fan is running constant what is it idling at once warmed up. Quote Link to post Share on other sites
BoostJunkie Posted November 3, 2007 Author Share Posted November 3, 2007 there is a sensor u take out when you remove your aircon and are meant to leave it plugged in there to save any of these probs occouring!and i'm guessing thats the plug in the pics in which you bridge the wires, which i have done.and i'm still getting the error code 51. Quote Link to post Share on other sites
jon5698 Posted November 3, 2007 Share Posted November 3, 2007 It idles at about 900rpm once warm Quote Link to post Share on other sites
