Hi All,
Basically i took the car for a spin the other day started fine when i got back i went to go out a hour later and it was like i had a flat battery i tried jump leads and still the same problem? i pushed started it and started no problems.
Any Ideas?
Ray
Could be starter motor, dodgy earth, dodgy +ve connection.
Start with basics, get the battery drop tested or try a known good battery. Then check connections etd
