Zeldoz Posted December 6, 2013 Author Posted December 6, 2013 Replace the lambs. For £11 it could potentially cure it I'm yet to try it Quote
sosolid Posted December 7, 2013 Posted December 7, 2013 I just checked and listened to the throttle bidy area and noticed 2 things. Firstly the idle control valve doesnt click as loud as it used to. Secondly theres a hissing noise coming from round the throttle body. How can i check for leaks. Is there a special way? Quote
sosolid Posted December 9, 2013 Posted December 9, 2013 how do u check for vacuum leaks???????? is der a @method@ to do this Quote
Zeldoz Posted December 9, 2013 Author Posted December 9, 2013 I would take off the intercooler piping going onto the throttle body and check for any rips or tears in the silicone and re-fit TIGHTLY. I know i dont have a vacum leak and i have the same issue, i doubt it thats.. but you never know! Quote
sosolid Posted December 9, 2013 Posted December 9, 2013 well cleaned the throttle body today and checked all silicone and they are good. might be idle control valve because wen i unplugged mine the speed of the engine didnt change. Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 Mines started to do this too around 2krpm, engine management light comes on briefly then off again Quote
sosolid Posted December 11, 2013 Posted December 11, 2013 mines working good now. i proper sprayed carb cleaner into the throttle body and cleaned it proper with a toothbrush and cloth. den took the battery terminal off so the ecu resets. started and now its fine. but i sprayed aloooooot in der. Quote
Zeldoz Posted December 11, 2013 Author Posted December 11, 2013 I'll give that a go! Cheers mate! Quote
Andym Posted December 18, 2013 Posted December 18, 2013 Been having similar problems in my GT, changed the plugs with platinums, cleaned up the plug wells/dizzy/rotor arm, changed o2 sensor as it was running an error code and finally cleaned my throttle today. throttle cleaner seems to have made all the difference. not sure why but problem hasnt come back yet... hopefully this is our solution. Quote
Zeldoz Posted December 18, 2013 Author Posted December 18, 2013 Okay il whip the intercooler pipe off next week. Did you remove the throttle body or clean it on the car? Quote
Andym Posted December 18, 2013 Posted December 18, 2013 i had the throttle body off because i was fiddling with the TPS but the instructions on the can said to start the car straight after, so i just just removed intercooler-TB pipe, sprayed it on the throttle plate and wiped it off and wiped around the body. Quote
