beefy Posted November 18, 2013 Posted November 18, 2013 Any help on me solving this problem thanks guys Quote
yaristurbo Posted November 18, 2013 Posted November 18, 2013 Oil pressure switch? Check oil level and wiring to it Quote
beefy Posted November 18, 2013 Author Posted November 18, 2013 Oil level is fine just under the full and I was told it could be a relief valve? Oil level is fine just under the full and I was told it could be a relief valve? Quote
AdamB Posted November 18, 2013 Posted November 18, 2013 The relief valve just bleeds off excess pressure. It will be the pressure switch as YT said, its a common fault. Quote
Chris Green Posted November 19, 2013 Posted November 19, 2013 Sort the OPS sooner rather than later, that's what nackered my first engine. Quote
AdamB Posted November 20, 2013 Posted November 20, 2013 Sort the OPS sooner rather than later, that's what nackered my first engine. The oil pressure switch has no bearing on the engine what so ever, the only thing it does is activate the low oil pressure light on the dash once a preset pressure is reached by the sensor. Quote
