Adam-Gt- Posted November 18, 2013 Share Posted November 18, 2013 The horn on my ep82 doesn't work probably do with the fact I can't even find it or even a plug or wire for it Where abouts isit located on them so I no exactly were to look Thanks Adam Quote Link to post Share on other sites
Burt-21 Posted November 18, 2013 Share Posted November 18, 2013 Hi not sure if this will help but mine didn't work on my ep91 I found out this was due to a brass gold coloured pin begone the boss kit steering wheel and it was bent and not making contact try this as a solution maybe Hi not sure if this will help but mine didn't work on my ep91 I found out this was due to a brass gold coloured pin begone the boss kit steering wheel and it was bent and not making contact try this as a solution maybe Quote Link to post Share on other sites
Adam-Gt- Posted November 19, 2013 Author Share Posted November 19, 2013 Cheers Burt I'll check that out then Quote Link to post Share on other sites
Burt-21 Posted November 19, 2013 Share Posted November 19, 2013 Not a problem it may be that it may not just one reason it might not work mate Quote Link to post Share on other sites
Adam-Gt- Posted November 20, 2013 Author Share Posted November 20, 2013 Bump !! There's defo nothing wrong with the wiring on the steering wheel side as when I press the horn inside the car the relay clicks Quote Link to post Share on other sites
