mikehardy92 Posted November 27, 2013 Share Posted November 27, 2013 I need to replace my ignition barrel on my Glanza, anybody know how? By looking at the new one it looks like there is some sort of locking pin that needs to be pushed in on the top or something? ThanksMike Quote Link to post Share on other sites
DennisV Posted December 3, 2013 Share Posted December 3, 2013 To be sure remove the negative from the battery. After that remove the plastics around the barrel so you can see the whole barrel. At the left side you will see 2 bolts holding it. Get them out. After that remove the plug at the back. Get the new one and fit it on the same place. There is only one way it will fit so dont worry. Put the plug in. Put on the negative and try it out. ;) Quote Link to post Share on other sites
richardc9052 Posted February 4, 2014 Share Posted February 4, 2014 Put current key into ignition, turn key and push the pin that you saw in, the barrel should pull out. reverse to replace Quote Link to post Share on other sites
